th350 fairbanks kit down shift problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2011, 10:23 PM
im having problems with a fairbanks shift kit . i installed as per the instruction and made it full man valve body as per instructions. problem is it shifts great up shifting but will not manually shift back into first untill im almost at a dead stop. this is in a mud bog truck and i really need it to down shift under full throttle when needed. any suggestions?
Old 07-31-2011, 08:57 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Since I do not know how the Fairbanks kit is designed... and I doubt the kit is too different from a TransGo kit.
Is the governor used in the Fairbanks kit? Or is it eliminated?
Vacuum modulator used or removed?
My guess is the governor circuit is flooded and the trans will not bump back to first like it should. This happens in a TransGo kit install about 2 out of 10 times.
A hole is drilled into the governor circuit may help. About .065 size hole is a good size to start. Valve body removal is needed. Drill the hole in the circuit at the rear of the v-body is easiest
Old 07-31-2011, 09:10 AM
A holes drilled into the governor circuit may help. About .065 size hole is a good size to start. Valve body removal is needed. Drill the hole in the circuit at the rear of the v-body is easiest
governor is used with springs to hold wide open the modulator is there but no vac to it . the instruction say to leave modulator in but not use vac to it. however it does give an option to remove it and use a plud to hold the valve.,but the instruction say not to use the plug if using the manual valve body option
Old 07-31-2011, 09:14 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Vacuum modulator is there to blow off pressure in reverse. Reverse pressure can go over 300 if a aluminum plug is installed in place of the vacuum modulaotor
Sounds like this kit is similar to TransGo. The hole in the governor circuit should fix the problem. The hole plows off some pressure to allow the down shift to first
Old 07-31-2011, 09:32 AM
thank you ill give it a try!!!
Old 07-31-2011, 10:12 AM
i just want to be correct drill a hole in the governer circuit anywhere at the rear of the case correct? i just dont want to put it in the wrong place. if you had a diagram that would be great again just dont want to put it in wrong place.
Old 07-31-2011, 10:27 AM
fairbanks
its exactly the same as a transgo system try what crosley sugested,those kits are made by superior they put a fairbanks logo on them(fairbanks have not been in business in years )
Old 07-31-2011, 10:41 AM
im not sure i totaly understand where to drill the hole at? drill it in the case ? where will the excess fluid go just dont want to mess it up
Old 07-31-2011, 11:03 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Remove the valve body and drill the hole in the valve body. In the governor circuit at the rear of the valve body.
You installed the kit, I figure you know a little about the transmission?
Old 07-31-2011, 11:15 AM
ok got thanks i thought that just wanted to be sure it was there and not the case side thanks
Old 07-31-2011, 01:01 PM
thank you again works like a champ !!!!!
th350 shift problems razzygirl Transmission - Rearend 1 05-15-2011 11:43 AM
th350 shift kit jgh64pkup Transmission - Rearend 16 12-10-2009 08:50 PM
th350 won't shift out of first tilyn62 Transmission - Rearend 3 09-19-2007 09:27 PM
What will a TH350 Handle? Many Th350 Quetions, Shift kits? Warrant Transmission - Rearend 2 12-18-2005 09:46 PM
TH350 won't shift down to first conestogaman Transmission - Rearend 2 12-15-2004 10:27 AM
