Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 fluid capacity
Old 06-26-2003, 07:55 PM
adtkart adtkart is offline
adtkart@aol.com
Unless the convertor is smaller than the original, it should hold 10 qts. Fill it up, checking it closely, with engine running while adding. You may get some inacurate readings on the stick after adding because of the fluid in the tube. Make sure the temperature is up to normal, and you have run it through the gears, when the level shows full. There is no reason that you should have to add any after 24 hours if it is filled properly the first time, unless you have a leak.
