TH350 fluid flow in cooler - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2004, 09:04 PM
Jmark's Avatar
Question on the TH350 cooler lines. Does ALL the fluid go through the cooler and lines or just some of it? Thanks.
Mark
Old 04-26-2004, 07:22 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
After a couple cooling line mishaps in the past I would have to say all of it, and rather quickly too.
Mistakes are for learning purposes.
Old 04-27-2004, 07:14 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
No , all fluid is not routed through the converter.
The main line pressure is fed to the valve body and routed through the pump body to the coverter .
Cooler line with pressure OUT from the tranny comes directly out of the converter then to the cooler.
Cooler line pressure depending on the set-up can run 40 - 60 psi on the high side and flow 1.5 to 2.0 quarts per minute
