TH350 Front Pump Question
Hi All,
This is my first time posting here, because I have a question on installing a TH350 front pump. I did a search but didn't find what I was looking for. I picked up this trans that had already been disassembled. I have it all reassembled but don't know if there is a certain position the front pump needs to be in. It wasn't marked before taken out. Do the holes only line up in a certain position? Or does it matter? Thanks in advance. |
Pretty sure it's keyed to fit only one way...
Russ |
The pump can go in only one way for the bolt holes to all align correctly. Below are some links showing the pump, how to inspect it, how it's aligned/centered and how to use dowels made from bolts w/their heads cut off to help install the pump.
The pump has both a gasket under it and an O-ring around the outside of it to seal it to the case- both need to be in place. http://www.hotrodders.com/forum/th35...ch-145361.html http://koti.mbnet.fi/~narker/camino/tranny2.htm http://www.carcraft.com/projectbuild...dup/index.html |
Thanks guys, once I looked at it closer I saw how a couple holes are offset to align it only one way but still appreciate the responses.
| TH350 Pump Seal Question | jogasz28 | Transmission - Rearend | 2 | 08-20-2011 07:57 AM |
| I need a th350 front pump gasket and o-ring. Where can I buy these locally? | scapegoat | Transmission - Rearend | 6 | 05-30-2010 10:20 AM |
| TH350 Pump seal question | aberenz | Transmission - Rearend | 5 | 04-30-2009 09:12 PM |
| TH350 front pump primer valve - HELP!! | sandman351 | Transmission - Rearend | 2 | 08-07-2005 08:37 AM |
| th350 pump question | Tissue | Transmission - Rearend | 2 | 05-22-2004 03:41 PM |
