th350 front seal removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2011, 11:11 AM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
Need to replace the front seal, but I can't get the old one out. Tried levering it out with a screwdriver but it won't budge. Any tips or special tools? I'm not a BFH kind of guy, so maybe I'm just being too timid.
Old 02-11-2011, 02:27 PM
oldguy829's Avatar
Wiki Edits: 88
front seal removal.
I've made a hook to fit my slide hammer, still no luck, just bends the lip of the seal.
The new seal has a flange on the metal lip. The book shows this flange to be on the outside. The existing seal doesn't have a flange on the outside. Is it possible the seal was placed in backwards from the book? With the flange on the inside?
Old 02-11-2011, 04:32 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I think they would had to have installed it with the pump split, not likely. It may have been installed with the good old brown sticky sealer that dries hard as a rock.
You could always pull the pump (so as not to let anything contaminate the trans?) and gently tap it towards the inside, see if it budges. I've rebuilt a couple of T-400's, but never rebuilt the old pumps, I'm not sure what goes on inside them.
Old 02-12-2011, 08:32 AM
S10xGN's Avatar
Gotta love a turbo!
Go to Autozone, Pep-Boys, etc and buy this tool .
Old 02-12-2011, 09:05 AM
oldguy829's Avatar
Wiki Edits: 88
seal removal
Thanks for the support guys. It finally came out. Looks like it was put in with indian head shellac.
TH350 Seal beertracker Transmission - Rearend 4 01-25-2011 05:41 PM
T-350 dipstick seal awoodman Transmission - Rearend 5 06-09-2009 05:50 AM
front seal/ rear main seal...help mrobby440 Engine 2 05-11-2006 05:31 PM
Th350 seal removal SBC-S-15 Transmission - Rearend 1 04-04-2005 09:41 PM
Removal procedure of rear main seal Neophyte Engine 2 08-26-2004 12:37 AM
