th350 FWD clutch cushion plate - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2002, 09:02 PM
New Member
Post th350 FWD clutch cushion plate
hi rodders question has anyone intentionally left out the cushion plate in the forward clutch pack in a th350 ? I just had to try it,gee now doing so i can chirp the tires immediatly when the gear selector is put in the drive position with the brakes on.I ran it that way for about 5 months and then i later did a parcel tear down and reinstalledthe cushon plate.[note;i would not recommend this idea] mark p.s, < 50/50 warranty whichever occurs first 50 feet or 50 seconds>
Old 12-12-2002, 03:37 PM
2x4's Avatar
2x4 2x4 is offline
New Member
Post
Exactly why I never tried that!
Old 12-13-2002, 07:20 AM
Maverick's Avatar
Post
I am new on working on trannys so my terminology is a little weak. But, I have been told that if you remove every other spring in the forward clutch thingie that it will make it shift really hard. Any one ever tried or heard of this?
Old 12-13-2002, 12:38 PM
Post
[quote]Originally posted by Maverick:
<strong>I am new on working on trannys so my terminology is a little weak. But, I have been told that if you remove every other spring in the forward clutch thingie that it will make it shift really hard. Any one ever tried or heard of this?</strong><hr></blockquote>
No it'll make it even rougher when you first put it in drive. Forward clutch is not a shifting clutch so it doesn't effect shifts. Only the direct and intermediate clutches are shifting clutches on a th350. I personally don't remove springs. Removing springs may cause delayed down shifts and clutch burn up due to slow release.
