th350 gear ratio and engine RPM questions
My pickup has a th350, 3.73 rear end and 27.6" tall tires. Torque converter is a 2000 stall.
I have done all the math, and if anyone would like to double check me, please feel free. I SHOULD be at 4k RPM at 88 mph, 3k RPM at 66 mph, 2k RPM at 44 mph. (while in 3rd gear which is 1:1 for the th350) What I am actually getting is 4k RPM at around 50-55 mph. Which is waay off what the math is telling me. So something is not working correctly and I'm not sure what. I checked to make sure that I am actually shifting into 3rd when I think I am. Disconnected the kickdown, just in case. I shifted manually through the gears to ensure I was in third. All good there, shifts fine and at the appropriate RPM Is my converter malfunctioning? I know there will be some slippage, but this seems pretty extreme. |
Actually everything sounds right. At 6000 rpm you should be at 110 miles an hour. Have you verified your speedo is correct? That is the first thing you should do.
I got 5k at 110 mph. Hmm, it seems very high to me
thats right , I was wrong at 6 grand.5 grand for 110 mph.
Still, you need to verify your speedo. with a 3.73 the motor is gonna rev higher at cruise speed.Once you calibrate the speedo,then it is what it is. |
You might be right on with the speed. To be perfectly honest I was guesstimating my speed. The speedo is a dakota digital that is all wired up and ready to go, however I have not yet calibrated it. It just seems way off. However it may be my internal sensor!
I will update tomorrow after I calibrate the speedo with a GPS.
To check and calibrate your speedometer
http://www.bushnell.com/products/oth...ed-gun/101901/ To check and calibrate your tachometer http://www.princessauto.com/workshop...ser-tachometer 5000 rpm at 110MPH is just about right for 3.73's with a 27.6" tire. MPH x 336 / tire dia x gear ratio= rpm For stock low stall converter with foot to the floor substitute 355 for 336. For a high stall converter foot to the floor use 360 for 336 in the formula. Last edited by F-BIRD'88; 02-24-2011 at 07:33 AM. |
| 1987 Chevy shortbed 4x4 gear ratio questions | newattruckin | Transmission - Rearend | 6 | 05-09-2010 06:13 PM |
| 383 with th350 and 3.73 gear questions | elano | Transmission - Rearend | 13 | 01-25-2010 12:17 AM |
| Chevy TH350 Speedo gear Questions? | labreejr | Transmission - Rearend | 3 | 12-05-2008 09:53 AM |
| Rear Gear Ratio questions!! | dastone | Transmission - Rearend | 2 | 01-04-2007 10:15 PM |
| gear ratio questions | mustangman1968 | Transmission - Rearend | 4 | 12-15-2003 01:19 PM |
