Odd that the solenoid wiring would be reattached and everything left as though the TCC was working. The reason for my curiosity is because I have a TH350C in my '80 Malibu wagon. Original tranny never been out of the car, has only had filter and fluid changes.
Because it has well north of 250K miles on it, I figure it is bound to need a rebuild eventually and the idea of switching it to a non lockup has been considered so the TC availability would be better, but generally speaking I like the lock up. Anyway, thanks for the input. |
It also has the Unibell Case/Housing, fits Chevy & BOPC. These are getting very hard to find now.
I can't remember for sure but, I think a passage/port behind the Pump is blocked which cancels the need for the Valvebody Mod. TCC feed possibly. |
there was a hole to be drilled in the stator support so the oil behind the converter hub seal would drain out... otherwise the seal could blow out from pressure build up
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| TH350 or TH350c identification | 355Nova | Transmission - Rearend | 2 | 03-23-2010 01:16 AM |
| th350 or th350c? | malibus~most~wanted | Transmission - Rearend | 5 | 03-23-2008 07:39 AM |
| TH350 and TH350C What's the difference? | 83elky | Transmission - Rearend | 17 | 03-10-2008 12:23 AM |
| Replace TH350C with TH350? | 666ross | Transmission - Rearend | 2 | 11-03-2007 10:13 PM |
| TH350 or TH350C | HiPoVAN | Transmission - Rearend | 2 | 05-31-2003 08:32 AM |
