TH350 has no 3-1 kickdown...why? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2007, 02:46 PM
Berliner Bel Air's Avatar
Beyond the Sea
I bought a 1955 Buick this year. When I bought it the TH350 (350 SB Chevy engine) did not kickdown. It shifted very soft too. So I had a Transgo shift kit installed by a friend. The shifts are very nice now, crisp, and it will kickdown from 3rd to 2nd gear when I floor it. But at under 45 miles an hour this is not really enough, it should kickdown from 3rd straight into 1st I believe, but it won't. What could cause this behavior and what needs to be done to correct it?
Old 08-04-2007, 03:58 PM
Cape Cod Bob's Avatar
I don't know from personal experience but I have been reading Ron Sessions book on TH350's.
He states that downshifts are a result of Wide Open Throttle, which on factory installations is a secound cable to the tranny DETENT-DOWNSHIFT-LINKAGE.
He also states to leave this to the pros to adjust and proceeds to explain how it should be done.
Could be yours is out of adjustment, having just been worked on.
I would not be surprised if u had no cable and the tranny downshifts 3-2 as a result of other goings on in the tranny. revs, torque, speed.
The detent valve is located on the passenger side in front of the dip-stick location just above the tranny pan flange.This is where the cable would be attached.
The detent cable should reach its full limit of travel just as the throttle reaches Wide Open Throttle
According to the book.
Hope this helps
Old 08-04-2007, 04:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the detent cable hooked up?
Is the cable Adjusted correctly?
In the TransGo kit install....... were the governor springs installed that come in the TG kit?
Old 08-05-2007, 03:56 AM
Beyond the Sea
The kickdown cable is attached and adjusted so that at WOT the cable is fully pulled out.
The governor springs that came with the Transgo Shift Kit were installed.
Old 08-05-2007, 10:36 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
re-install the OEM governor springs... test drive
Old 08-05-2007, 11:50 AM
Did you check the detent arm on the valvebody?
They are prone to breaking/bending which will not force the valvetrain to full detent position. Check this if Crosley's latest suggestion does not help.
Kickdown on TH350 - won't downshift sabino56 Transmission - Rearend 2 12-28-2006 03:19 PM
th350 kickdown cable question Bill-E-BoB Transmission - Rearend 5 07-21-2006 10:33 AM
th350 + kickdown + problem sbc350 Transmission - Rearend 15 01-26-2004 02:08 PM
th350 kickdown ajustment jon_volk Transmission - Rearend 5 01-16-2004 07:17 PM
TH350 kickdown cable andybird Transmission - Rearend 4 07-25-2003 07:54 PM
