TH350 hesitates before engaging reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2010, 10:46 PM
This truck has been doing this for over 10 years and really isn't any worse than it was. It has a serious leak or two now so before I have it rebuilt I would like to know what causes it to hesitate. It takes about 3 or 4 seconds before it engages reverse, forward engages immediately. Valve body?
Old 02-27-2010, 11:26 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Does it act the same hot or cold? Kinda sounds like what I call morning sickness....
Old 02-27-2010, 11:37 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you can have several problem areas if this trans acted the same for 10 years.
excessive pump gear clearance will reduce the pump volume and cause a delay since more clutch packs apply in reverse than forward first gear.
The hard seal problem could be there now , but for 10 years , makes me wonder about that.
During the rebuild process I would suggest a good check of all clearances
Old 02-27-2010, 02:56 PM
It behaves the same hot or cold. I was expecting it to go completely out when I firts got it but it hasn't changed much in 10 years.
my th350 popped out of reverse and will not engage strokedout Transmission - Rearend 4 09-07-2009 12:39 PM
th350 stalls in reverse chev. Transmission - Rearend 6 07-02-2009 04:07 PM
th350 has only reverse Merickk Transmission - Rearend 1 01-04-2005 03:07 AM
th350 reverse double apply??? eskoskimo Transmission - Rearend 1 10-11-2004 06:07 AM
