th350
BIGSKY, I'm not sure I'm understanding the question exactly as you intended it but, you should not feel any "slip" in high gear at highway speeds, or any speed for that matter.
For example, if your crusin at say 60mph and you step on it, the vehicle should be responsive, there should be no lag. no slip, it should just go. It has been said that a torque converter is only 90% efficient, unless it is a lockup converter. But this 10% "slip" you will not feel, crusin down the road. Please feel free to interject if my understanding of your question is not correct. |
Thanks for replying Briscoe. I will try to explain better.
The truck seems to "surge" at highway speeds, like I am driving into gusting head winds. I know that sounds weird, but that is the best I can describe it. Also, my speed vs. rpm seems off. If the tranny was 100%, then for my setup 2,500rpm would be 77.57 mph, but its slower than that. If I figure a 10% loss though, then I would be going 69.8mph which sounds closer to my actual speed. I need to borrow a GPS and determine my exact speed at rpm. Regarding the kickdown, if I punch it, the tranny shifts down like it should and the truck accelerates as it should but still with that surging. Anyway because my truck seems to not be going as fast as it should per rpm, and it surges, I am just wondering if my tranny is slipping, maybe its a vacuum leak or something else. |
th350
OK BIGSKY, a vacuum leak would cause the trans to upshift late, take a long time to go from 1-2 2-3, like instead of 2nd gear at 15mph, it may be more like 2nd at 25mph.
If the trans was slipping in high gear at say 50 mph you should be able to feel it slip in reverse. Put in on a hill and back up under a load, if it slips this way then yes, it may be slipping in high gear. In reverse the high gear clutch drum is applied, so a problem in high should be a problem in reverse as well. Perhaps the surging is the engine.? Let's see what the gps tells us, ok? |
Reducing engine speed has changed several things, among them transmission line pressure and the relationship of throttle position to engine vacuum which will false signal the modulator valve whether it's linkage or vacuum. These will affect shift points and servo holding pressures. There should be about 100 to 200 RPM differential between calculated and reality with a OEM torque converter. That could be another issue, the rev reduction on the engine could drop under the converters flash stall which would increase connective losses which you would see as increased engine RPM against road speed, also, tranny oil temp will go up. Bogie |
Good point about throttle position vs. vacuum with the 2.75s, I hadn't considered that, but it surged with the 3.50s also. 100 - 200 differential; good to know. I will be borrowing a gps to find out my actual speed, to see if there is a problem there. The surging is actually more noticeable at revs above 2,000, beyond where my stock converter should be hooking up I think. Maybe my converter is not healthy? I rebuilt the engine in this truck about 5 years ago and it ran fine after that, same tranny as now, both stock from factory. This surging is a new problem since my restoration, so its something that has happened with my reinstallation of the engine/tranny, or something has gone bad since when I took the truck apart and put it back together. The idle isn't perfectly smooth either [cam is mild], maybe I have an electrial problem... I installed new wires and plugs, but used the same cap from before the restoration. Maybe I should try a new cap? The surging is driving me a little nuts, so thanks for any suggestions. |
It is my jetting!
It didn't dawn on me that this could be the problem, because the truck ran fine before.. but I did put on different headers and much shorter exhaust, same mufflers. Plus I added one of those black plastic type plates under the carb [4 hole version] to stop the vapor locking. I didn't think my changes would lean it out because I went from long 1 -7/8" tube 3" collector headers to 1 5/8" 2.5" collector shorty headers. I guess the mild motor is much happier with this setup and runs enough better to actually require more fuel? Is that possible? Still will check tranny slip with GPS, but at least the "lean" surge is diagnosed! Thanks for the help!
And throw that edelbroke away and get a good Holley or Q-jet (preferably a Holley) edelbrock is great for a cruiser SB that rarely sees over 3,000 rpm, but I have seen them destroy motors.
I was at the track one night and I heard that there was a mustang that was "popping and cracking" out on the top end. I asked what they ment and one guy said that some hot shot had a stang with a mildly built motor with a 750 edel on top, and the carb was leaning out in the high RPMs. So if course this was the highlight of the evening, everyone was betting when the motor popped or burned a piston all thru the test and tune and up into the qualifying. SEVERAL ppl tryed to tell him that he would hurt the motor if he didn't do something about the carb so somewhere thru test and tune he had someone run out and get a tune kit for it, and they put LARGE jets and rods in it, to no avail it would tear you up idling and detonate out on the top end. Needless to say halfway down the track on his first race a piston let go. After that I'v had a bad taste in my mouth about edelbrock carbs, and if you look close even vic uses holleys on their dragsters. Of course this is the same guy that caught his nitrous system on fire because the solenoids and switches weren't on a fused circuit.
Ok, fixed a vacuum leak at the carb base, and have re-jetted and the carb seems good, surging nearly gone.
Checked speed with a GPS; 2,500 rpms is 68.6 mph, if the converter was locked up I would be going 77.5 according the to math so I am slipping nearly 9mph or 11.6%... The truck still doesn't feel right in 3rd, so I drove the truck in 2nd at 2,500 rpms and it feels good, no surging in 2nd. Also, as suggested I drove backwards up hill from a stop to test 3rd, I couldn't feel a slip and I can get the tires to spin doing that drill too, so maybe its not slipping enough to feel, but slipping some...
Overdriv, that could have been it but the car was useing the factory fuel pump with a regulator for fuel and if I had a carb that wouldnt take the gas when I got it up there, it would be in the trash.
Last edel I had I got on a motor, carb was BRAND new it got ripped of and sold. I got $125 out of it tho. |
| 700R4/4L60 3rd Gear Slip Questions | ih1974d1100 | Transmission - Rearend | 5 | 06-19-2006 04:27 PM |
| TH350 3rd gear slipping? | 2kcj | Transmission - Rearend | 1 | 04-10-2006 06:20 PM |
| 700r4 3rd gear slip | broken | Transmission - Rearend | 7 | 03-15-2005 12:25 PM |
| th350 slips in 3rd | 71ss | Transmission - Rearend | 9 | 11-08-2004 09:44 PM |
| TH350 not engaging in 2nd and 3rd | NoEgoMan100 | Transmission - Rearend | 11 | 10-21-2004 05:35 PM |
