TH350 Input shaft types early vs late - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2012, 06:22 PM
Hey. I had to order a new forward drum w/ input shaft.
But they sent me one with the later style input shaft that has the teflon seal where it goes in the output shaft.
It will fit now that I pulled the bushing........but the shaft is 1/4" shorter than my old one.......and the spline length on the input side is not as long either.
Will this work or should I get the earlier style drum/input shaft?
Thanks, z
Old 10-24-2012, 06:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks, z
If by "later style input shaft" you mean the shaft is for the TH350C w/lock up torque converter (used 1981- up), a non lock up torque converter will not fit the lock up style shaft.
If this is the case, get the older non lock up style input shaft.
Old 10-25-2012, 07:47 AM
No that's not it. Chevy upgraded the input shaft in 77 or so.......when you pull the bushing out of the output shaft, the newer style will fit ........but I worry about it being 1/4 inch shorter.......and the spline length being shorter too.....Sessions talks about the bushing/newer teflon seal....but doesn't elaborate on switching them......
z
Old 10-25-2012, 07:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I toss out the shaft with the teflon seal....
the nick is nothing to worry about, unless there is a crack. oh wait, that question was on yellow bullet forum
forward drum, input shaft, th350
Excessive input shaft endplay (T-350) ntx_gearhead Transmission - Rearend 6 11-14-2010 04:33 PM
yet another TH350-C question. TCC input center shaft removal? fast68 Transmission - Rearend 2 11-20-2009 10:52 AM
Early and Late Ford 302 66Moostang Engine 4 05-14-2008 06:50 AM
late roof in early car 31chevy Body - Exterior 3 09-21-2007 05:48 AM
700r4 Input Shaft/Drum Interchangable to 4l65E Shaft/Drum?? syclone477 Transmission - Rearend 3 01-01-2004 04:06 PM
