th350 int clutch height to low? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2009, 10:50 AM
Getting near the end here. When I stack the intermediate clutch plates followed by wavy washer thats all well and good. Prob is I depth mic from front pump sitting surface down to high point on wavy washer and get about .200 inches less than the flange to contact point on pump. Not cool right? What I'm yaying is there'll be .280 inches of room between wavy washer on top of plates to where its supposed to contact on pump. What should it be? Not .200 I wouldnt think?
Old 11-27-2009, 12:26 PM
if i install one old steel and disc i get .100". the old stuff looks ok. is this a prob?or would i be best add a couple old steels?
Old 11-27-2009, 12:55 PM
ericnova72's Avatar
More for Less Racer
You're not forgetting the pressure plate are you?? Been a while since I have been into one, maybe I'm thinking wrong, but I have never seen an Intermediate with more than 3 clutches.
Old 11-27-2009, 01:25 PM
Originally Posted by ericnova72
You're not forgetting the pressure plte are you?? Been a while since I have been into one, maybe I'm thinking wrong, but I have never seen an Intermediate with more than 3 clutches.
I like it but there aint one to be seen and the other oddity is that the little marks the steels made in the case originally. I come up to those like BANG SPOT on. So got me. Hoping someone chimes in. Neither of the books I got call for plate either
Old 11-27-2009, 01:39 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the intermediate clutch requires a pressure plate into the case first.
Depends on apply aluminum piston in the pump to use 2 frictions or 3 frictions with match steel plates ...
then the waved plate is on top of these plates before the pump is installed
Old 11-27-2009, 03:33 PM
Got it. thanks fellas
htd clutch problem 2112jb Transmission - Rearend 2 02-16-2006 07:15 AM
TH350 Roller Clutch help Chris_K Transmission - Rearend 7 10-16-2005 07:44 PM
TH350 Manual Low Problem HELP! andrewhotrod Transmission - Rearend 3 01-25-2004 10:25 AM
T-350 slipping... low oil pressure... diagnosis? Funkster Transmission - Rearend 10 03-27-2003 12:28 PM
how low on fluid (TH350) before it quits moving? HotRodF100 Transmission - Rearend 4 10-11-2002 06:34 PM
