TH350 issues
Hey all i got a trans issue wanna see what you guys think. is a 73 th350 my line pressures are very low 10psi at idel around 60 under load in drive. trans has a b&m shift kit w 1 check ball new torque converter new modulator valve w the red band around it. the question is am i looking at a bad front pump or an over haul??
not sure of internal work. shift kit was installed wrong from previous owner.replaced kit w b&m kit car will move but have low line pressure in all gears.rpm has to be 3 to 4k for the trans to engage
if 1 check ball is not installed near the inner modulator valve, main line pressure will be low in all ranges.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
OK. the b&m kit only has one ck ball in it i put it in were the instructions say to place it. the valve body in my trans has one ck ball in it. got a picture of were this ball is supposed be located???
| th350 issues | jesso350 | Transmission - Rearend | 7 | 06-12-2010 11:32 AM |
| TH350 Issues | terminator0723 | Transmission - Rearend | 6 | 05-25-2009 02:23 PM |
| Th350 Tranny swap DRIVE SHAFT ISSUES | sugar ray | Transmission - Rearend | 10 | 05-04-2009 11:55 AM |
| Transmission swap: TH250 to TH350 Torque converter issues. | 35oldstruck | Transmission - Rearend | 5 | 05-21-2008 03:43 PM |
| TH350 reverse issues | DoubleVision | Transmission - Rearend | 2 | 12-08-2005 05:53 PM |
