th350 kickdown - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2011, 09:25 PM
Dan
th350 kickdown
I have a mildly built turbo 350 with a shift kit in it with a 3200 stall converter with a ratchet shifter, do I need a kickdown cable so I get more line pressure when I down shift? Or can I just put a manual valve body in it?
Old 03-25-2011, 10:48 PM
blwn31's Avatar
You only need the kick down cable for automatic kickdown as far a I can remember. You can manually downshift it all day. My Dad has had his car set up this way for 20 yrs. with no problems.
Keith
Old 04-06-2011, 12:54 PM
My 350 has a kick down cable but doesn't downshift. I also feel like it shifts too early, it'll be in third before I know it. I don't know, when I got the tranny the kick down cable was removed and plugged. I took the pan off and installed the kick down, but can't seem to feel it work. So far the tranny has held up better than the previous rebuilt one, and it's from some old guys shed.
Old 04-06-2011, 01:48 PM
Originally Posted by RotorHead
...I also feel like it shifts too early....
You can adjust the shift point by pulling the hose off the vacuum modulator, located on the transmission, and turning the screw that is inside the tube. Test drive and readjust if necessary.
Old 04-07-2011, 01:00 AM
bentwings's Avatar
bentwings
The kick down can be deleted. I don't have a cable at all on mine and it works just fine. If you really want to downshift just use the shifter.
I have an adjustable modulator and adjusted it so the average shifts are firm but not harsh. The tires just chirp on moderate acceleration around corners but that is the locker working.
TH350 kickdown won't engage Bill-E-BoB Transmission - Rearend 5 04-02-2010 01:14 PM
TH350 has no 3-1 kickdown...why? Berliner Bel Air Transmission - Rearend 5 08-05-2007 10:50 AM
TH350 kickdown keotie Transmission - Rearend 5 03-30-2006 01:19 AM
th350 + kickdown + problem sbc350 Transmission - Rearend 15 01-26-2004 01:08 PM
TH350 kickdown adj. john69 Transmission - Rearend 1 10-22-2002 02:47 PM
