TH350 kickdown adj. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2002, 01:37 PM
Post TH350 kickdown adj.
I just installed the rebuilt TH350 in my 77 vette and could anyone tell me the proper way to adjust the kickdown cable?
Old 10-22-2002, 02:47 PM
dklong's Avatar
Post
john69 the kick down cable adjustment is near your throttle cable bracket. with the engine off , on some cables you push or pull out a metal tab, then pull your cable back toward the fire wall all the way . then open your throttle all the way this should adjust your kick down linkage properly, then test drive. if it dont shift right try adjusting the cable again.
