TH350 Kickdown Cable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2011, 08:55 AM
ZackMethvin's Avatar
I know this has been covered before. However, I have a little different question. I have a T-Bucket running a 283 with a lockup TH350 & 1800-2000 stall converter. It has a tunnel ram and i am wondering about running the kickdown cable and how i can hook it up to the tunnel ram. Anyone make a bracket for this application or should i just leave the kickdown cable off?
Old 10-03-2011, 08:39 PM
Wiki Edits: 27
pontiac parts
mid sized pontiacs with 350 chevy engines used a kick down cable that hooked up inside the car to the gas pedal. ( I saved the pieces from my donor car for one of my T buckets running 2 4's.
Old 10-03-2011, 10:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Good point- the same set-up was also used on the Cutlass from around '69-'75, also the Buicks up to about the same year. That type cable uses another square hole in the firewall near where the throttle cable enters the cabin. I did a quick search but didn't see the complete gas pedal just the pad.
Th350 Kickdown Cable - no movement 70bird Transmission - Rearend 1 07-08-2008 08:46 AM
th350 kickdown cable question Bill-E-BoB Transmission - Rearend 5 07-21-2006 09:33 AM
TH350 Kickdown Cable dsours Transmission - Rearend 2 07-04-2006 10:53 PM
TH350 Kickdown cable dawg Transmission - Rearend 1 10-04-2004 01:20 PM
TH350 kickdown cable andybird Transmission - Rearend 4 07-25-2003 06:54 PM
