TH350 kickdown housing leaks - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2006, 02:09 PM
54belair's Avatar
I have a TH350 in my '54 belair, and when I park on a hill (or my driveway!) where the nose is higher than the back, tranny fluid leaks out the hole where the kickdown cable goes into the tranny. I've replaced that "hold down" piece, replaced the rubber washer/gasket, and it still leaks. I'm not talking a couple drips either. If I let it sit for a night it will nearly drain the tranny. I've tried explaining it away as "sweat from all that horsepower" but nobody believes me anymore. Is this common with these tranny's? What's the fix? Any ideas will be appreciated. Thanks!
mac
Old 06-22-2006, 03:39 PM
mac
You must have a crack in the plastic part that goes into trans case or a crack in the case, when I put one of those o-rings or grommets in I always use a little silicone and let it set up possibly overnight before use.
