Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TH350 Leak
Thread: TH350 Leak
Old 09-19-2003, 08:49 PM
Bumpstick's Avatar
Bumpstick Bumpstick is offline
Hammer and a torch
It has a small seal but it requires removal of the pan and the linkage internal... You can then pull out the shaft and replace the seal which is very small and replace the linkages and pan and refill and be on your way... Just take care as to the disassembly of the linkage pieces and its no big deal...
