Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TH350 Leak
Thread: TH350 Leak
Old 09-20-2003, 08:31 AM
adtkart adtkart is offline
BT is right. Usually the tool comes with a tool for removing the seal and a tool to re-install the new one. It is relatively easy to do and does not require removal of the pan. If you are removing the pan to change the fluid, it can be done the other way, but that usually means laying under the dripping fluid to change it. You also have to be careful to make sure you get the linkage and manual valve hooked up right.
