Ck the cable to make sure it's not cracked where it goes into the case. If it's ok, all you need to do is drop the pan, un-hook the kickdown cable then remove the cable from the trans, 7/16" bolt I think. Change the 0-ring and put it back together. RTV will most likely NOT work since it's oily.
