Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TH350 Leak
Thread: TH350 Leak
Old 12-04-2006, 08:29 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
IF your trans detent cable or the filler tube have the rubber sealing sleeve ( NOT the O-ring)
It is best to install the rubber sleeve into the tranny case first , then the cable end or filler tube.
