TH350 leaking filler tube - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2012, 03:53 PM
Dipstick O ring style and sleeve style
Hey everyone. How are you all?
I know I am late to this topic, however I saw a post from MIKE FROM SM that raised my eyebrow!
Mike are you saying you can buy the sleeved type dipstick tube and install it in the O-ring style tranny case???
I also have a leaky tranny, although I think my problem came from the engine swap. It would appear that the dipstick tube mount got lost while the tube was out.
I don't have much room to work around the tranny, frame and headers!
Maybe installing the sleeve style will benefit me in the long run, if it is possible that is...
Thank you for reading my new post in this "outdated posting. Any advise will be greatly appreciated!
StepsideDreamer
Old 01-27-2012, 05:11 PM
Crosley's Avatar
Wiki Edits: 1659
sidestep,
members you are posting to : have not logged in here for some time.
Trans case did not change. Proper filler tube for the rubber sealing sleeve design function fine in trans case
