TH350 Leaking through shifter linkage hole - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2006, 11:52 AM
T-bucket23's Avatar
Wiki Edits: 26
I have a th350 in my TBucket that is dripping a bit of fluid through the shifter shaft where the linkage connects. I am guessing there is an o ring or a small lip seal in there, if so is it easy to replace and what size is it.
Thanks
Chet
Old 05-29-2006, 12:34 PM
Jmark's Avatar
That leak is an easy fix with the correct tools, which are available at most auto parts stores like Napa or CarQuest. Not very expensive either. Seal may have to come from a trans shop if not available at the auto parts store. Here is what they look like.
Another one on eBay cheap!
Mark
Old 05-29-2006, 02:53 PM
T-bucket23's Avatar
Wiki Edits: 26
Thanks for the reply, I saw the other thread right after I submitted my question.
I will see if I can find the seal locally.
Thanks again
TH350 driveshaft yoke leaking Jmark Transmission - Rearend 11 08-16-2008 12:38 PM
th350 shifter adjustmen on a 69 camaro dawg Transmission - Rearend 3 05-23-2005 09:07 PM
th350 leaking only under load justspeed Transmission - Rearend 6 10-31-2004 04:18 PM
th350 leaking only under load justspeed Transmission - Rearend 10 10-06-2004 10:03 PM
TH350 Manual linkage position (picture) pcesak Transmission - Rearend 5 03-15-2004 04:53 AM
