th350 lockup switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2009, 06:18 PM
th350 lockup switch
i recently installed a th350 with a lockup torque in my 79 4x4, the truck originally didnt have a lockup. so now i gota figure out how im gunna hook up the switch. does it run off of the distributer? or shud i just run a seperate aftermarket switch that i turn on for going down the highway?
Old 06-24-2009, 04:54 AM
SSedan64's Avatar
Most 80 and newer trucks had the TH350C with lockup. They used a vacuum switch on firewall which activated with high vacuum then through the Brake switch under dash to disengage lockup. You could rob the parts from a junker or just run 12V from Brake switch to toggle switch & wire to the trans switch. I recommend using a new Brake switch for an 80 up truck that has more terminals so the lockup will disengage when you try to stop.
Old 06-26-2009, 11:30 PM
k thanks i found the vacuam switch assembly in my buddys bone yard. is it safe to run my tranny without the lockup switch hooked up for the time being ?
Old 06-27-2009, 01:50 AM
SSedan64's Avatar
It wont hurt the 350C to not have the TCC locked.
Old 06-28-2009, 12:10 AM
sweet. thanks alot
Trinary Switch from Vintage Air ElegantInventor Electrical 29 06-15-2011 06:44 PM
Wiring Neutral Safety Switch / EZ-Wire Kit horvath Electrical 15 01-20-2008 12:35 PM
72 chevelle ignition switch assembly problems customdrumfinishes Electrical 9 08-10-2006 05:06 PM
bad brake light switch on master cylinder? flamedfordbronco Electrical 3 07-10-2005 05:34 AM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 08:31 PM
