Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th350 low roller clutch and 700r4?
Old 05-15-2004, 07:00 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
===== in your first post you appear to quote the invoice;
" i looked at the invoice and it says "Low Roller Clutch 700R4 (early) 82-2/9/87"
that is the same roller clutch as in the t-350 and would explain why it fits the t-350 center support you have. If the retaining snap ring will install and hold the roller clutch in place it sounds correct to me.
It does not need to look the same , it needs to function the same. There are variations on design from different manufacturers
Originally posted by Tissue
if by center support you mean the cylinder part that the roller clutch slips onto. i have the one from the th350 and the 700r4 roller fits on it perfectly. however it doesnt look the same. im lost as what to do. maybe they sent the wrong part...
