TH350 -which is main line pressure port? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2007, 10:19 AM
sabino56's Avatar
Which is the main line pressure port on TH350? I see 2 ports on right side - one by vacuum modulator and one towards front. I found some pictures of TH350 with features numbered which I attached. If you can see the pics - which number is correct port?
Thanks!
Ed
Name:	TH350 Right Side.jpg
ID:	17434   Click image for larger version
Name:	TH350 Left Side.jpg
Old 01-06-2007, 12:20 PM
brian0605's Avatar
mostly confused
Last journal entry:
What do you mean pressure port?? Port one is vacuum from manifold source, I think #7 is the kickdown/passing gear cable,hooks to the Carb linkage,#8 and #9 are the trans cooler line hookups supply and return,#4 is Dipstick tube hole,#10 is for a vent line can be left as is or you can hook up a small pc of hose to route it away from mud and trash if it is going to be in a 4wd application. Nothing hooks up to any of the other things you have labeled.I hope this answers your question......Brian
Old 01-06-2007, 12:41 PM
sabino56's Avatar
Thanks for reply.
I wanted to measure transmission oil pressure to set up transmission. There are tables on correct trans oil pressure at various RPM, etc. + I'm following some advice on setting up vaccum modulator which requires measureing pressure. From reading some stuff - it appears that one of the measuring points is after governor and one is pressure right from pump. I can find anything on which is which.
Thanks
Ed
Old 01-06-2007, 12:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks!
Ed
2
I wish you luck. I have never set the tranny up as the info was posted.
Old 01-06-2007, 01:07 PM
sabino56's Avatar
Thank you
I have some questions about the transmission - bought it cheap and it's of questionable heritage. I think it's worth checking trans oil pressure. I've screwed around with vacuum modulator so much - I'd like to get it back to nominal and start again. I appreciate any adivce.
Ed
Old 01-06-2007, 11:35 PM
brian0605's Avatar
mostly confused
Last journal entry:
I can't say for sure I have never set up a trans like that either. I have always just used a stock non adjustable modulator,and pulled and plugged the vacuum line at the track. I know it's not the best way but it did work for me. Brian
Old 01-07-2007, 02:35 PM
sabino56's Avatar
Well, it turns out it's a real pain to get to the pressure port - I have headers which block easy access - so I just left it alone for now. I'll have to get some other fitting & hose to get to it and without burning myself when it's running.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
BBC rectangular port intake, oval port heads.. wildman926 Engine 14 10-15-2004 12:49 AM
Fuel Pressure DoubleVision Engine 18 05-31-2003 06:49 AM
WEIRD oil pressure christopher406 Engine 32 11-27-2002 08:49 AM
Fuel Pressure Variance slomotion Engine 2 04-02-2002 02:25 PM
