Th350 modulator valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2011, 12:54 PM
chevroletman223's Avatar
Dan The Man
In my 70 chevelle, the trans is shifting way sooner than id like it to, however if i disconnect the vacuum line from the modulator valve, it shifts exactly where id like it to. My question is, can i do damage to the tranny by having the vacuum disconnected? i wouldnt think so but i wanted to ask anyways. I may try an adjustable modulator, but for now will i do damage? thanks in advance. Dan.
Old 10-12-2011, 02:58 PM
modular
I am not sure but I think damage can be caused by disconnecting I do know your modular can be adjusted inside the hole where tubing is connected Small flathead , screw counterclock wise two to four rotations then drive to see if it is where you like
TH350 modulator valve spring udu56 Transmission - Rearend 2 05-18-2011 06:02 AM
Help removing broken modulator valve clamp bolt on TH350 lizardking7750 Transmission - Rearend 21 06-06-2010 07:53 PM
TH350 modulator valve spring RocketSwede Transmission - Rearend 2 11-30-2008 07:50 AM
modulator valve th350 studebaker46 Transmission - Rearend 1 02-12-2007 04:28 AM
modulator valve th350 studebaker46 Transmission - Rearend 2 02-11-2007 08:15 PM
