th350 no 2nd gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2003, 07:00 PM
Exclamation th350 no 2nd gear
Hi there, I'm new here so please be kind.
I have a 78 K10 4X4 with a TH350 with a 305 in front of it. It currently doesn't seem to have 2nd gear. It worked fine till one day, no slipping no noise. It just shifts from 1st to 3rd, also it won't stay in 3rd when you let off the gas. It will shift back into 1st and stay there till you shift into neutral then back into drive, then it'll go back to 3rd. None of the other gears slip (it will power brake fine in 1st and reverse). The fluid isn't burt, I haven't pulled the pan yet (As I don't have anywhere to do it at my apartment). I do have a place to work on it if need be. I've rebuilt severall motors, so I'm mechancally compentant (just not with automatic transmissions ). Any help would be appreciated.
Old 07-09-2003, 10:53 PM
67 Nova 400sbc.4L60
No second gear.
Sounds like second roller clutch is broke. That explains the sudden loss of second gear. Time for a rebuid.
Old 07-10-2003, 08:56 AM
I was thinking thats what it might have been. Just wanted a second opinion before I started to tear it apart. Thanks
