th350 no forward gears
i pulled my engine apart for a cam swap and then the freshly built th350 will not pull in forward gears, only reverse.
i have changed the filter and with the tire's off the ground it acts fine going through the gears, even when i pull it down in low, but put the car on the ground nothing!! please help!! |
didn't have motor out, had it apart, changed the filter, and fluid level is right.
thanks for the reply. |
i guess its on to another builder.
i was hoping that sumone had an easy fix. has anyone ever had any luck with redneck performance out of Texas? |
reverse operates good?
this tells me the input shaft is connected- transfer power,,, pump is making good pressure. manual low (1st) , still no movement? sounds like a forward clutch problem as mentioned. Seals , clutch pack burned up , cracked piston. fluid level is up??
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Would have to concur on the forward clutch failure could be a seal or a one of the pump rings, But its going to have to come apart for sure.
thanks for the replies!! time to take it out one more time..
would not be so bad if i had a place (other than the dirt) to work on it.. thanks again for the replies.. |
| bbc what gears to run.? | chevelle4542speed | Engine | 5 | 12-07-2006 05:47 PM |
| TH350 jammed between gears? | mittleiderj | Transmission - Rearend | 2 | 10-11-2005 05:55 AM |
| T-350 to 700r4 swap? | trumick | Transmission - Rearend | 6 | 09-23-2005 08:19 PM |
| What's needed for a th350 to a th400 swap? | Fil | Transmission - Rearend | 2 | 09-16-2004 02:09 PM |
