th350, no manual 1st gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2006, 12:30 PM
matt_ramsey's Avatar
Your Basic Moron
I had my transmission rebuilt this summer and, as some of you may know, it has been a terrible experience and i'm trying now to fix some of the problems myself. One big problem i'm having is that I have pretty much no manual control in first gear. If I take off with the shifter in first, the transmission will shift into second just as if the car was in "drive" (at around 4500 rpm at the absolute latest). Furthermore, I cannot downshift into first from any gear. What may be causing this problem, and is it something I could fix myself with any degree of ease?
Here is some more info you may find useful:
The transmission is a TH350. The rebuilder told me it was originally from a 6 cylinder, and he made some adjustments internally to make it equivalent to an 8 cylinder version.
shifter is a Hurst Pro/Matic 2 ratchet, but i had an old "indy-matic" in it before. I have made certain that when the shifter is in the first gear position, so is the selector on the transmission.
The detent cable is hooked up and appropriately adjusted.
Old 01-02-2006, 08:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
It is not a problem, the tranny is designed to do that.
there is a valve in the v-body that needs to be blocked in place to defeat this function of the tranny
Old 01-02-2006, 09:05 PM
Your Basic Moron
well i trust your input, i was worried because it doesn't behave that way in 2nd gear and before the rebuild i could hold it for ... well, let's just say i never found the limit. Is there any way to adjust it so it runs more like it did before? 4500 rpm kind of sucks at the track if you feel me.
Old 01-02-2006, 09:07 PM
Your Basic Moron
also, what do you think is up with having no 2-1 downshift?
Gear Vendor racing juiced66malibu Transmission - Rearend 1 09-15-2005 07:53 AM
Edelbrock Gear Drive!~!~ Help!! boneyard Buick Engine 1 05-27-2005 03:59 AM
Rear-end Setup opinions RObs71Nova Transmission - Rearend 6 03-11-2005 05:54 PM
TH350 Manual Low Problem HELP! andrewhotrod Transmission - Rearend 3 01-25-2004 10:25 AM
Th350 not going into gear Big86inthestixx Transmission - Rearend 2 11-13-2003 09:00 PM
