TH350 - no movement
I have a 72 Buick GS 350 with a TH350. I recently took out the engine and transmission for a good cleaning and all new seals and gaskets. I get it all put back together yesterday. Took it for a drive everything was perfect until I slowed to almost a stop and when I took my foot off the brake, I had no drive. Tried reverse, nothing. Tried 1 and 2, nothing. Basically I have Park and 5 neutrals. Never gave any warning, no slipping, no noises.
The fluid was a little high, so I used a vacuume to siphon some out. But still nothing. I thought once it cooled off I might get something, but today still no catch in any gear.
Now this is when I got my service manual out.. doh... The only thing I can see that I have done wrong is I have the cooling lines to the radiator mixed up. The fluid should flow from the transmission to the top of the rad, down through the rad, and back. The way I have it is that it flows to the rad and has to be pushed up through the rad and then back. Would this really have a harmfull effect? The only seals I did were the front and rear shafts. I did remove the bolt from the selector linkage to remove that seal but it looked too good to mess with so I put the selector bracket back on.
Im ready to take it out again but if someone can tell me anything to try first it would be great. Thanks guys.
