Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th350 no seems like its stuck in neutral
Old 01-15-2012, 03:18 PM
gonzo08383's Avatar
gonzo08383 gonzo08383 is offline
Last journal entry: brakes
i put a 350 converter on a 350-c once. i was doing a burnout and it went boom. a th350-c has a nipple like thing on the input shaft and a regular converter will not fully mesh the splines. i removed the converter and found i had stripped the splines out of it. pump was fine tho. if you have an electrical connector on you trans then its a 350-c(lockup). reg. 350's are non lockup.
