-   -   th350 no seems like its stuck in neutral (http://www.hotrodders.com/forum/th350-no-seems-like-its-stuck-neutral-212155.html)
matt921 01-09-2012 09:44 PM
Ok so this is what seems to be going on. I was driving the car an it seemed fine had reverse drive 1 2 park. So what happen I was going to the gas station everything seemed to be going good. Hit a stop sign started to take of an it seemed like it just went into neutral. Seemed kinda odd so i pulled off to the side of the road. Got to a stop an went threw all the gears thinking it was low. So i went and checked fluid it looked fine alittle high but nothing to be worried about. Like looking at the stick about this much over full _ . So i thought that maybe it was my linkage crawled under the car an it seemed like it was still hooked on. No leaks or anything. When it happened no sound just like i bumped the shifter an it went into neutral
Another weird thing was a while ago i was driving (i have a hurst quarter stick) and I pulled it down to second an nothing happened, so i slammed it back an it went downshifted. I was thinking maybe the linkage was off need a little adjustment. But the only things I can think of is maybe the linkage inside the motor the nut fell off. Or Clogged filter. I hope its nothing bad like a pump gear. The converter is brand new less than 200 miles on it. So any idea's please. I'm going to check it out tomorrow pull the pan an see if i can see anything.
gonzo08383 01-12-2012 05:43 PM
check your line pressure
68NovaSS 01-12-2012 06:31 PM
I've seen all the bolts come out of the converter on a T-400 once, never made a sound, when the last one dropped off, that was it, free revving.
dklong 01-12-2012 07:39 PM
it sounds like you lost your direct clutch .
prostreet6t9 01-13-2012 07:20 PM
I'd pull the pan and see if the linkage came loose on the inside.
tnsmith10 01-14-2012 06:26 AM
x2 on this.. if you did a converter swap and didnt get the converter all the way in, its possible that you broke the pump on mating the trans to the engine.
gonzo08383 01-15-2012 03:18 PM
i put a 350 converter on a 350-c once. i was doing a burnout and it went boom. a th350-c has a nipple like thing on the input shaft and a regular converter will not fully mesh the splines. i removed the converter and found i had stripped the splines out of it. pump was fine tho. if you have an electrical connector on you trans then its a 350-c(lockup). reg. 350's are non lockup.
