th350 no seems like its stuck in neutral - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2012, 09:44 PM
Ok so this is what seems to be going on. I was driving the car an it seemed fine had reverse drive 1 2 park. So what happen I was going to the gas station everything seemed to be going good. Hit a stop sign started to take of an it seemed like it just went into neutral. Seemed kinda odd so i pulled off to the side of the road. Got to a stop an went threw all the gears thinking it was low. So i went and checked fluid it looked fine alittle high but nothing to be worried about. Like looking at the stick about this much over full _ . So i thought that maybe it was my linkage crawled under the car an it seemed like it was still hooked on. No leaks or anything. When it happened no sound just like i bumped the shifter an it went into neutral
Another weird thing was a while ago i was driving (i have a hurst quarter stick) and I pulled it down to second an nothing happened, so i slammed it back an it went downshifted. I was thinking maybe the linkage was off need a little adjustment. But the only things I can think of is maybe the linkage inside the motor the nut fell off. Or Clogged filter. I hope its nothing bad like a pump gear. The converter is brand new less than 200 miles on it. So any idea's please. I'm going to check it out tomorrow pull the pan an see if i can see anything.
Old 01-12-2012, 05:43 PM
gonzo08383's Avatar
Last journal entry: brakes
check your line pressure
Old 01-12-2012, 06:31 PM
68NovaSS's Avatar
Wiki Edits: 9
I've seen all the bolts come out of the converter on a T-400 once, never made a sound, when the last one dropped off, that was it, free revving.
Old 01-12-2012, 07:39 PM
dklong's Avatar
it sounds like you lost your direct clutch .
Old 01-13-2012, 07:20 PM
prostreet6t9's Avatar
Differential/Driveline
I'd pull the pan and see if the linkage came loose on the inside.
Old 01-14-2012, 06:26 AM
tnsmith10's Avatar
when will it rain???
x2 on this.. if you did a converter swap and didnt get the converter all the way in, its possible that you broke the pump on mating the trans to the engine.
Old 01-15-2012, 03:18 PM
gonzo08383's Avatar
i put a 350 converter on a 350-c once. i was doing a burnout and it went boom. a th350-c has a nipple like thing on the input shaft and a regular converter will not fully mesh the splines. i removed the converter and found i had stripped the splines out of it. pump was fine tho. if you have an electrical connector on you trans then its a 350-c(lockup). reg. 350's are non lockup.
Stuck in neutral Arrowhead Hotrodders' Lounge 17 12-16-2008 07:48 AM
TH350 trans problem, goes to neutral Some Car Guy Transmission - Rearend 2 09-20-2007 11:08 PM
TH350 stuck in 1st???? Ichoptop Transmission - Rearend 14 05-11-2007 08:01 AM
95 camaro stuck in neutral solgood71blazer Transmission - Rearend 2 12-13-2004 01:06 PM
th350 stuck in first spankthru Engine 6 06-25-2003 10:25 PM
