Th350 no shift into first - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2011, 01:19 AM
Got a question for the trans guys out there. Driving my Camaro home from work yesterday and half mile from home, car started to take long to shift into second. Last couple of blocks away it almost wouldn't go into 2nd on its own. Pulled it into the garage and checked fluid. It was approx. 2 1/2 qts low. Topped it off and rechecked fluid level. Drove it again and no luck. It will shift through the gears if I shift it manually. I will check the vacuum hose to the modulator tomorrow morning. Just seems like it was a gradual thing as opposed to the hose coming off and stop shifting. It's a 468 cu.in. hyd. roller cam, with 560/540 lift, 294 degree advertised duration, TH350, 3,000 stall with anti-ballooning plate, B&M Master Racing Rebuild kit, B&M Shift kit, adjustable modulator, B&M Trick Shift fluid used,3.73 Auburn Posi, 275/50R15. Been driving it for about 7 yrs now and approx. 8,000 miles. Any info would be greatly appreciated. Thank you.
Old 08-02-2011, 09:59 PM
no second
2 1/2 qts low is not a good thing,you say it shifts manaully forward/reverse or 1 2 3?
Old 08-05-2011, 01:22 AM
yup but I actually found out it was the hose to the vacuum modulator. It must have started splitting on the way home cause it started acting up more and more as I drove. Seems odd to happen that way, but I crawled underneath the car and looked at the hose. It seemed fine at a glance but when I reached up and touched the top of the hose where you can't see it, I felt an edge. I pulled off the hose and found it split about a half inch which exposed the tip of the modulator. This explained the no shift. I replaced the hose and the problem went away.
Old 08-05-2011, 04:37 PM
that good it was something simple but you should find out why you were 2 qts low on fluid
Old 08-05-2011, 11:19 PM
Dipstick gasket/ seal in trans leaks. Replaced it several times and seal it with silicone. Works for about 9 months at a time, then leaks again.
th350 shift adj again sooper Transmission - Rearend 5 05-22-2010 12:58 PM
th350 shift kit jgh64pkup Transmission - Rearend 16 12-10-2009 09:50 PM
th350 won't shift out of first tilyn62 Transmission - Rearend 3 09-19-2007 10:27 PM
What will a TH350 Handle? Many Th350 Quetions, Shift kits? Warrant Transmission - Rearend 2 12-18-2005 10:46 PM
TH350 won't shift down to first conestogaman Transmission - Rearend 2 12-15-2004 11:27 AM
