TH350 - Not Going Into Gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2006, 07:37 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
The TH350 I installed behind my 350 SBC is not going into gear. Just got the engine started this weekend for the first time and tried to shift the trans to see if it would go into gear once I had the cam broken in. I have a new vacuum modulator on it which is hooked to the vacuum tree on the intake.
The trans was picked up second hand and has been sitting for two years that I know of. The internals were clean when I changed the filter prior to installation. I filled the converter with one quart of fluid prior to installation.
Was that enough? Could the modulator need adjustment?
The trans is connected to a column shift linkage via a Lokar gear selector shaft which is moving the selector shaft as prescribed.
Any suggestions as to possible fixes I might try before dropping the trans out for a full rebuild would be welcome.
Old 09-18-2006, 09:21 AM
astroracer's Avatar
Check out this thread from a week or so ago...
Used th400 not working
You have the same problem... Not enough fluid.
Mark
Old 09-18-2006, 09:54 AM
Jmark's Avatar
One quart in the converter to startup is fine, but you still have about 10 more quarts to go. Start it up, ck the stick, keep adding until "full", then run through the gears, ck again, fill if necessary.
Old 09-18-2006, 10:54 AM
T-bucket23's Avatar
Wiki Edits: 26
Mine took a little over 8 from dry to full with a mid sized converter. You also need to be carefull not to overfill it. Hopefully you didnt damage the pump running it dry during the cam break in. Im not a tranny guy so maybe it wouldnt hurt it
th350, no manual 1st gear matt_ramsey Transmission - Rearend 3 01-02-2006 09:07 PM
TH350 speedo gear color john69 Transmission - Rearend 7 12-12-2004 07:57 PM
th350 not going into gear phillip24 Transmission - Rearend 4 03-29-2004 08:02 PM
TH350 and what happened to 2 gear? Fryksten Transmission - Rearend 5 02-25-2004 07:46 AM
th350 1st gear manual shift problem desman Transmission - Rearend 6 02-08-2004 03:15 PM
