TH350 oil pump sheared - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2006, 10:23 AM
New Member
While testing today I ground to a halt, no drive from my reconned TH350 box with manual body.
I took the box out and the two lugs on the oil pump drive cog have sheared off. It's only had 3 hours use. I haven't stripped it any further yet but wondered if anyone knew why this would happen?
I did overfill it by mistake, about a pint too much, other than that I can't see I have done anything wrong.
Old 01-02-2006, 07:25 PM
Ricky Rocket's Avatar
Drive it like a rental!
I would guess that the torque converter was not aligned with the oil pump gear when the trans was installed. If the slots on the torque converter don't line up with the pump, it causes damage to the pump gear. Inspect the torque converter hub, repair the pump and reinstall. Make sure the torque converter is in all of the way before you put the trans in. The quick method for this is to try and put your fingers behind the torque conv. (between it and the pump). If you can get your fingers in there, it is NOT installed all of the way, rotate and work it around until it goes in all of the way.
Good luck,
Rick
Old 01-07-2006, 02:18 PM
New Member
Thanks Rick
Repaired and reinstalled. The torque converter clearance was a 1/16 which I think must have been the problem. I made a shim between the engine and gearbox to give just over an 1/8 clearance.
So far so good.
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 05:03 AM
Bad news, oil pump shaft mychevystang Engine 10 04-25-2005 03:54 PM
Oil Pump Problem??? riesman20 Engine 11 05-25-2004 10:06 PM
distributor gear / oil pump wear ?? help bskaggs Engine 9 05-04-2004 09:55 AM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
