TH350 output shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2007, 12:24 PM
TH350 output shaft
I have a TH350 with a 3 in. output shaft. From what Ive read, I now know this means that it's from a truck that was originally equipped with a transfer case. Is there any way (asides from swapping the output shaft for the correct one) to run a 6 (or 9) in. shaft with extension housing. If there isn't, how much would a transmission shop charge to do that, and would it be more cost effective to buy a used transmission from the junkyard with the correct output shaft
Old 06-06-2007, 06:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the out put shaft must be swapped for the correct length shaft
Old 06-07-2007, 04:27 PM
Last journal entry: car is painted
And it would be expensive to change it. Everything has to come out of the trans to change it.
Old 06-07-2007, 07:11 PM
That explains the short shaft. I asked a trans guy here that exact question about 5 years ago, and he quoted me $75 for a "gut-swap". I'd figure more like $100 these days.
TH-350 Output Shaft Seal Help leejoy Transmission - Rearend 2 01-24-2007 08:51 PM
Different size output shaft on c4? nitrous_69stang Transmission - Rearend 3 04-17-2006 10:51 AM
Crosley?? T-400 Output Shaft 'O' Ring 68NovaSS Transmission - Rearend 2 12-13-2005 06:35 PM
transmission 700r4 output shaft slop catscan4free Transmission - Rearend 3 01-25-2004 08:11 AM
replacing 700r4 in f-body with th350 with 9"tail shaft striker86 Transmission - Rearend 6 05-25-2003 08:48 AM
