TH350 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2007, 06:33 PM
catfishtn's Avatar
TH350 problem
OK guys, need a guru!
2 weeks ago, I put a newly rebuilt th350 in my 78 Chevy P/U. Last week, I had some brake problems, so I totally rebuilt the brakes. Later found out I had a bad brake hose that would gradually cause the R/F wheel to drag.
Took my wife to work, on the way home, brake started dragging, had to really stay on the gas to get home.
Now the trasmission is starting to shift funny, won't go into 3rd until about 35 MPH, and when it does, it sometimes shifts back and forth from 2-3 several times.
Now, somebody tell me,
WHAT DID I BURN UP
Any ideas would be appreciated, also already adjusted the kickdown cable, and all vacume modulator line is good.
Thanks in advance.
Old 03-30-2007, 08:28 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Well, since you admittedly abused the trans, most likely you overheated it and fried a clutch pack.
I am no trans guru but that is what it sounds like to me.
You may have gotten lucky and just coked the fluid, so I would change fluid and filter before anything else.
Old 03-31-2007, 06:35 AM
catfishtn's Avatar
update
update.... noticed this morning that truck seems to be starting from a stop in second gear, then won't shift till about 35 to third.
Just some more symptoms
Old 03-31-2007, 07:50 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
check the governor first for stuck valve , it is easier.... press on round cover near the back end of main case.
You may need to drop the pan & the valve body to clean the v-body and free up stuff.
If there is metal debris in the pan , there is more troubles that cleaning may not help.
Old 03-31-2007, 08:12 AM
catfishtn's Avatar
will try that, thanks. Hope I don't have to take trans out, still recovering from installation.
strange th350 problem 49chevysd Transmission - Rearend 17 10-13-2005 04:05 PM
Found low oil pressure problem.... kc_ksom Engine 2 09-06-2005 07:01 PM
Please Help, Problem with TH350 kehi66 Transmission - Rearend 3 06-20-2005 01:34 PM
th350 speedometer problem john69 Transmission - Rearend 4 06-17-2003 06:38 PM
th350 problem..... oldcarguy85 Transmission - Rearend 2 04-24-2002 04:06 PM
