th350 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2007, 09:38 PM
383silverado's Avatar
th350 problem
well happy fathers day!!!
, busted my drive shaft carrier bearing yesterday !!! replaced it 2 months ago and don't drive it very often about 2-3 times a month, anyways changed the u joints and c-bearing today i think the trans is shot ( th350 ) couldn't get the yoke on the trans all the way, it would only go in about 1 inch but the yoke is about 6 inches does any one have any idea why ? the trans output shaft was real loose i could move it around pretty good.
the good thing is that i have a th400 from hughes with a shift kit 2500 stall i can put in it's place but still would like to know what happened to my th350 ?
Old 06-18-2007, 09:06 PM
Crosley's Avatar
Wiki Edits: 1659
pull the tail housing off the tranny to see what the problem is
Old 06-18-2007, 09:16 PM
will do thanks
strange th350 problem 49chevysd Transmission - Rearend 17 10-13-2005 04:05 PM
Please Help, Problem with TH350 kehi66 Transmission - Rearend 3 06-20-2005 01:34 PM
th350 1st gear manual shift problem desman Transmission - Rearend 6 02-08-2004 03:15 PM
th350 speedometer problem john69 Transmission - Rearend 4 06-17-2003 06:38 PM
th350 problem..... oldcarguy85 Transmission - Rearend 2 04-24-2002 04:06 PM
