TH350 Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2006, 03:24 PM
catfishtn's Avatar
TH350 Problem
Hoping I can get some help. Driving my 78 P/U the other day, I felt something strange in the trans (th350). Since then I have no 2nd gear! no slippage, no strange noises, no burnt fluid, nothing. Now will shift straight from 1-3 in Drive, 1 2 work in manual.
Any Ideas?
Thanks in advance.
Joe
Old 01-25-2006, 09:08 PM
sbchevfreak's Avatar
Licenced Automotive Technician
It could be you have a leaking intermediate servo, and the higher line pressure in manual 2 is enough to apply the band, but regular line pressure in D is not.
Old 01-25-2006, 09:11 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Any Ideas?
Thanks in advance.
Joe
A broken intermediate sprag.
manual 2nd will hold because the coasting band is applied.
Old 01-25-2006, 09:40 PM
D'oh!! I completely forgot about the sprag!!! Must have woke up on the stupid side today, !
Just an quick Q, Crosley have you ever heard of putting the OWC's from a 700R4 into a 350? I've been told with some finagling of the selective plates they will fit and be stronger than the originals, but haven't had the time to try it.
Old 01-26-2006, 03:54 AM
catfishtn's Avatar
thanks
Guess I was hoping it would be something that wouldn't require rebuild. Bought the truck last year because the 700R4 in my pontiac went out No luck at all lol. and no, I am not hard on my Tranny's. Just bad luck. Well guess it's time for 2 rebuilds!
Old 01-26-2006, 06:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the later 700 center support and roller clutch assembly will fit the t-350. There are serveral different thickness of the wide sprag 700 unit, so checking clearance of the L/R clutch pack is very important.
the inner race fits both designs.
Old 02-02-2006, 11:47 PM
Thanks, just what I was looking for. Don't know when I'll finally have the time to get back on the project, the wife has me running ragged. Sorry it took so long to reply, my computer has been a little on the fubar side lately.
strange th350 problem 49chevysd Transmission - Rearend 17 10-13-2005 04:05 PM
Found low oil pressure problem.... kc_ksom Engine 2 09-06-2005 07:01 PM
Please Help, Problem with TH350 kehi66 Transmission - Rearend 3 06-20-2005 01:34 PM
th350 speedometer problem john69 Transmission - Rearend 4 06-17-2003 06:38 PM
th350 problem..... oldcarguy85 Transmission - Rearend 2 04-24-2002 04:06 PM
