TH350 probs - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2011, 02:46 PM
Last journal entry: 76
TH350 probs
ok I changed the pan gasket because of small leak filled with fluid drove it to my grandpas went to leave the next mornin no drive.
reverse works though Any help is appreciated.
Old 11-03-2011, 03:01 PM
when you first put it in drive it jumps a little bit then nothin
wish I had a 700r4
Old 11-03-2011, 05:16 PM
Did you get enough fluid back in it?
Old 11-03-2011, 07:37 PM
I added 7 quarts but it was a quart low still added another quart still didnt move.
The thing that gets me is it kicks when I first put it in gear then nothing not sure what it could be.
I read something that said to give it a little gas in reverse or something said a valve could be stuck im not sure though.
Old 11-03-2011, 07:56 PM
found out today my kickdown cable was broke would that be the cause.
I think thats it
Old 11-03-2011, 09:18 PM
gmc1990rodder's Avatar
It could cause it but doubtful.. did you change the tranny's filter while you had the pan off also? And just wondering but with just a filter change my th350 only holds around 4.5 quarts? Are you checking the fluid when it is warm and running?
Old 11-04-2011, 12:30 PM
checked it while running still not sure
Old 11-04-2011, 12:31 PM
no I dint change filter should've but didn't
Old 11-04-2011, 01:20 PM
That would be my very next step! Draining some of the old fluid out could have trapped sediment on top of your filter. usually if you ask for a new filter it will come as a kit along with a new pan gasket for just a few bucks.
Old 11-04-2011, 02:03 PM
kinda another thing i thought guess I'll try it it was a little dirty in the pan.
Old 11-04-2011, 02:04 PM
since it has new tranny fluid in it ill just catch it and reuse it would that be ok.
Old 11-04-2011, 02:12 PM
also forgot to state it slipped right as I pulled into his drive way just a little bit.
Old 11-04-2011, 02:17 PM
NEVER a good idea to reuse any types of fluid... in the lil time that it was in there it could of picked up any type of sediments or metel from the trans !!
Old 11-04-2011, 02:21 PM
ahh ok its only 2.48 a quart so I'd be better of replacing it anyway then.
Old 11-04-2011, 02:37 PM
I was never the transmission guy I can do the work but I know a guy who builds racing trans. but he lives far away now. He always told me I needed a 700r4
I personally like them better too.
th 400 probs rixjohnson Transmission - Rearend 2 11-20-2010 08:17 PM
TH350-C sealed/now probs Fergusonic Transmission - Rearend 3 01-08-2008 12:03 PM
ac probs bigtim Engine 1 06-09-2006 12:17 AM
Big Probs... Big.Big Probs...NO PULSE! Haulin327 Electrical 4 03-03-2006 06:42 AM
Is there any probs with my ign? 5.0Towncar Engine 8 11-01-2002 07:29 PM
