TH350 Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2009, 10:28 AM
TH350 Question
Im having an issue with my tranny shifting from 2nd to 3rd when I have it in manual 2nd. It usually shifts at around 4600rpm. I want to hold it for about 5500. I was told it sounds like a valve body problem. How do i remove the valve body? Is it as simple as unscrewing the screws and pulling it off? I thought about Putting a TCI manual valve body in the tranny. Anybody had any experience with those?
Old 04-09-2009, 12:34 PM
The stock valve body will cause an upshift regardless of selected position of the shift lever at a point where the governor is armed for the WOT upshift, this is normal OEM function. Only solution is a modified valve body and governor.
Bogie
th350 question 39chevykid Transmission - Rearend 2 09-25-2006 07:29 PM
Th350 question Jeeper426 Transmission - Rearend 9 09-06-2006 09:02 PM
Question: TH350 acting weird Mad_Max Transmission - Rearend 6 08-03-2006 08:50 PM
TH350 Manual Valve Question Pantload Transmission - Rearend 6 02-19-2006 01:48 PM
T-350 rebuild question Marcus Transmission - Rearend 3 07-01-2004 07:48 PM
