th350 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2009, 06:10 PM
Last journal entry: Motor build up 2
th350 question
Hey my father in law is using a th350 he had it rebuilt and has less then 500 miles on it, as he is still building the truck. we just pulled the motor and trans to have the motor crank redone. Anyway tranny fluid started leaking from the tail shaft and then we pulled the motor and tranny appart and it leaked like the main seal was leaking. Im thinking the tranny wasn't redone right or something went wrong.
My question is this:Should trany fuild be coming out the front or real seal? and how many quarts of fluid does a th350 take?
Old 08-24-2009, 06:30 PM
SSedan64's Avatar
If the trans is tilted fluid will run out. Fluid can run out the pump in front and when converter is removed. http://www.tciauto.com/Products/Tech...d_capacity.asp
Old 08-24-2009, 06:33 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A t-350 trans can hold up to 10 quarts of fluid when the trans and converter are both empty.
tilting the trans around will result in fluid loss if there are openings , converter out of the pump , etc.
Old 08-25-2009, 12:05 AM
Wiki Edits: 85
The seals are there for one purpose, to prevent oil leaks WHEN THE TORQUE CONVERTER and YOKE are installed. If they are not installed the seals CANNOT stop any leaks.
th350 question 39chevykid Transmission - Rearend 2 09-25-2006 08:29 PM
Th350 question Jeeper426 Transmission - Rearend 9 09-06-2006 10:02 PM
Question: TH350 acting weird Mad_Max Transmission - Rearend 6 08-03-2006 09:50 PM
TH350 Manual Valve Question Pantload Transmission - Rearend 6 02-19-2006 02:48 PM
T-350 rebuild question Marcus Transmission - Rearend 3 07-01-2004 08:48 PM
