-   -   Th350 question (http://www.hotrodders.com/forum/th350-question-219129.html)
theitalian 05-07-2012 10:38 PM
Th350 question
Hello I'm rebuilding a th350 when I Air check my direct crutch pack I have to plug another hole in the pump housing for it to work is this normal?
cobalt327 05-08-2012 01:04 AM
The photo below is from Jakeshoe's thread on the TH350. It shows the forward and direct drums on the pump (there's a hole in the bench for the pump to fit through) w/all the sealing rings and thrust washers, etc. assembled as it would be in a completed tranny.
http://www.studebaker-info.org/tech/...50aircheck.jpg
You sure you don't have any damaged, missing or broken rings/seals or cracked piston, etc.?
theitalian 05-08-2012 07:51 PM
Seal rings are new and not leaking i took the drum apart again all the piston seals are good i cant find any cracks anywhere the air comes out the reverse port if i plug the hole with my finger it will work....
theitalian 05-08-2012 08:32 PM
Took it apart again inspected everything again now it applys with out pluging the reverse port but still leaks past the reverse port.
theitalian 05-12-2012 07:04 PM
Transmission is in and works great
