Th350 question
Hello I'm rebuilding a th350 when I Air check my direct crutch pack I have to plug another hole in the pump housing for it to work is this normal?
The photo below is from Jakeshoe's thread on the TH350. It shows the forward and direct drums on the pump (there's a hole in the bench for the pump to fit through) w/all the sealing rings and thrust washers, etc. assembled as it would be in a completed tranny.
![]() You sure you don't have any damaged, missing or broken rings/seals or cracked piston, etc.? |
Seal rings are new and not leaking i took the drum apart again all the piston seals are good i cant find any cracks anywhere the air comes out the reverse port if i plug the hole with my finger it will work....
Took it apart again inspected everything again now it applys with out pluging the reverse port but still leaks past the reverse port.
Transmission is in and works great
| th350 question | cutthroatkid | Transmission - Rearend | 2 | 01-23-2012 04:35 PM |
| th350 question | 49fordp/u | Transmission - Rearend | 3 | 08-24-2009 11:05 PM |
| TH350 Question | terminator0723 | Transmission - Rearend | 1 | 04-09-2009 12:34 PM |
| th350 question | tampaelcamino | Transmission - Rearend | 2 | 07-03-2005 05:42 PM |
| TH350 Question | DoubleVision | Transmission - Rearend | 1 | 10-06-2003 01:33 PM |
