th350 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2005, 11:20 AM
th350 question
Hello all, Im new to this forum and have a question about the th350 transmission. I have recently rebuilt my transmission and will be installing in when I have the money to buy my converter. My question is on the external cooler lines which line is out to the cooler and which one is back in to the transmisssion. There is two stacked on top of each other (on the outside of the transmission and Im usure which one is out and which one is in. I have noticed that automatic transmission information is very limited on the internet and no one seems to know much about these "mystery boxes" that shift cars. Any help would be great, thanks in advance for reading and for any responces one may have.
Old 07-02-2005, 12:09 PM
Never mind guys, I found the information by a link I found from a previous post in this forum. The upper is the "in" and the lower is the "out". Seems this is the same on the glide, th400 and 700r4 as well. Thanks for reading.
Old 07-03-2005, 06:42 PM
GoneNova/406's Avatar
you're right but it really doesn't matter.
TH350 Manual Valve Question Pantload Transmission - Rearend 6 02-19-2006 02:48 PM
TH350 Drive Question my350camaro84 Transmission - Rearend 2 06-10-2005 10:23 PM
TH350 gap between converter and flexplate QUESTION chrisgarrison Transmission - Rearend 6 12-27-2004 12:32 AM
Two part TH350 overdrive question killerformula Transmission - Rearend 2 11-22-2003 02:34 AM
Dumb question - how to fill TH350 with lube? Limey Simon Transmission - Rearend 5 01-24-2003 03:43 AM
