Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350 rear seal leak
Old 08-02-2004, 02:06 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
Did you check to see if there were grooves worn in the slip yoke?
If so, either a repair sleeve can be installed (if you can find one) or a new yoke is in order.
If the yoke is OK, did you happen to apply a small amount of transmission fluid to the surface of the yoke, and inner surface of the seal?
If not, you could have prematurely worn the seal.
