Hotrodders Bulletin Board
#1
TH350 Rebuild Tech
I will be posting pictures and instructions of an actual TH350 rebuild for hi-performance use.
I do not intend for this to be a replacement for a tech manual. First time builders will likely need a tech manual. I would recommend Ron Sessions book "TH350 Handbook" in the HP Book Series. It has good pictures, alot of good info, but has some outdated info. Outstanding value for the money. This is an ongoing project, I will add to it as I go. I am not doing a step-by step pictorial, don't assume I have shown where every part goes, there will be some thrust washers I have installed and not taken an individual picture to show it because of bandwidth considerations. I may not always be available to answer questions, full time job, full time college, multiple car projects, and a family take alot of time. That said I hope this helps some understand the TH350 or maybe it'll help when you're elbow deep and have a question. First, A TH350 is known to be rough on bushings. Bushings are critical in that they allow the rotating parts to ride true on center, and for the lube to make it to the rear of the trans. Be prepared to replace almost ALL the bushings in a TH350. Might as well order a bushing kit, as well as a thrust washer kit. I would recommend you get at least 2 additional sun gear bushings individually also. Once the case has been cleaned, all threads checked and or repaired, and the rear case bushing installed you can start assembly. The first item to go in wil be the low/reverse apply piston. Its function is for oil to force it towards the front or bellhousing side of the trans, applying the low/reverse clutches. This allows reverse when applied simultaneously with the direct (high gear) clutches, and allows manual low gear when applied with the forward clutches. Manual low gear creates engine braking on deceleration. The low/reverse clutches do not apply in automatic range 1st gear. The low sprag (low roller clutch actually) causes first gear when only the forward clutches are applied. In the rare application that does not need reverse or low gear engine braking the low piston and low clutches can be deleted, and the feed holes in the case blocked. ![]() Install new seals on the low piston, these are square cut seals, not lip seals. Then push it into the rear of the case evenly by hand, aligning it properly so it will seat (there is a "tang"). Look at the park pawl notch to help index it. ![]() Then install the return spring and retainer using the tool pictured. ![]() ![]() Next you install the output shaft ![]() Be sure you have the output ring gear to case bearing in the case. Also be sure on disassembly you inspected and replaced as necessary the input shaft to output bushing shown here ![]() |
#2
Next goes in the output planet to output ring gear bearing or thrust washer depending on year.
Then the planet. ![]() ![]() Now you can install the low/reverse clutches, beginning with a steel, then a friction, alternating, ending with a friction. Note here, If you have a light duty core with low count low pack, unless it is a transbrake application or will be manually shifted into low for engine braking often, fewer clutches is OK, in some cases, where you are after every lat ounce of ET, using fewer clutches can cause less frictional loss in 2nd and high gear. "Turbulator" steel plates from a 4L60E will also help and are a direct drop-in. I am using Alto red frictions in this unit, however a stock tan clutch (I prefer Borg Warner) is more than adequate for even very high HP cars. A Hi-Energy Borg from a 4L60E is also a good choice. ![]() Once the low clutches are installed, you can install the anti-clunk spring (or case-saver). Both are pictured, the case-saver is solid and spreads the load over a larger area. Hold in place with assembly gel or vaseline and then install the low support. Be sure the low sprag inner race is not brinelled or has any unusual wear. ![]() Once it is pushed into place, install the snap ring, with the ends on each side of the spring or case-saver. Now is the time to air check the low clutches. You do so by applying pressurized air to the passage at the rear pan area of the worm casting in the case. (Pics later) |
#3
Next you install the 4 tang thrust washer into the large splines of the low sprag inner race, and then the sun shell and gear assembly.
Before this step, for HD use, you would have wanted to install additional sun gear bushings, 2 on each end, and re-drilled the lube holes. Shown here. ![]() Drop the sun shell/gear in, spinning in the output carrier until it falls in place. ![]() Install the input planet next, already pictured. Now, To prevent excessive endplay, a pump thrust washer can be installed on top of the input planet, then the regular thrust washer. Then install the small outside snap ring to hold it all in place. Check the output shaft for proper rotation, there will be some drag, especially in one direction. Check for excessive output endplay. If endplay is excessive, it can be tightened up by dis-assembling and shimming up the output ring gear bearing from the case. Now you drop the input ring gear on, spinning into place. ![]() Then install the 3 tang thrust. For racing and heavy towing use, you will want to machine the direct clutch piston down approximately .160" to allow for one extra friction and steel plate for a total of 5 frictions, and 5 steels in the directs. This can be accomplished on a brake lathe. I try to keep a few machined on hand, and machine several at a time when I do so. If you need one email me and if you can supply a core, I MAY be able to sell you a piston. Stock measurement is ~.835, I cut them to .675". Ideally you would pre-assemble, and check clearance using a 4 clutch pack, meaure the additonal thickness of the extra friction and steel, then cut the exact amount needed to leave you the exact clearance you desire. Rule of thumb on most auto trans friction clearances is ~.010" clearance per friction. So a 5 friction direct setup would work great with .050" clearance. It will work with less, I wouldn't go less than .040", and will work with quite a bit more, but excessive clearance can result in delayed engagement, busted lip seals, and unsatisfactory shift quality. ![]() Stock 4 piston direct piston vs. machined for 5. Next, HD applications should also get a hardened intermediate sprag race. It is darker colored than a stock piece. The intermediate sprag race and intermediate sprag (actually roller clutch) take a brutal amount of force on a 1-2 shift at high rpm. Even more so with harsher shift calibrations. It is the weakest single part of a TH350. This is not to say a TH350 is not tough, they are under-rated and can reliably handle in the 600HP or lb/ft range based on my experience. ![]() I also like to always use a NEW intermediate roller clutch for HD builds. My theory on a long lived setup is that the springs that force the rollers against the race must be in good condition to helps the rollers grab quicker and more evenly on apply. The parts go on the direct drum. ![]() ![]() |
#4
The direct drum should use a wider bushing even on stock rebuilds. Most bushing kits include the wide one.
![]() There is alot of load on this bushing, and it should ALWAYS be replaced on overhaul. ![]() Also check the inside bore of the drum for wear from the sealing rings. A small amount of wear can be honed out. Visual shiny spots with no detectable wear are OK. Next you will install the direct piston lip seals, and install the piston in the drum. ![]() Take note of the orientation of the seals, the lip will face towards the "oil" side of the piston, not the clutch side. Also take note, this is a hi-performace TH350 and I did NOT install a lip seal in the drum that would seperate the two halves of the direct piston. This is part of the process of "dual-feeding" the direct clutches. On a stock rebuild you would normall install this lip seal. You can do this on any rebuild but you must also block a passage in the case near the pump to prevent loss of pressure to the reverse circuit. Dual feeding doubles the area of the piston that has pressurized fluid on it in 3rd gear, more than doubling the capacity of the clutch. It is accomplished by most valve body kits without doing so internally but requires a "transfer" plate and gasket to be added under the support plate in front of the valve body. I prefer internally dual feeding because it leave out the additional gasket and eliminates that one extra possibility for a pressure loss resulting in burnt 3rd gear clutches (Yes it has happened to me). All transbrakes will require dual feed of the direct clutch, as well as many manual valve bodies. Here is the passage that must be blocked. I usually tap this hole with a 3/8" tap, and cut off the end of a 3/8" bolt. I then slot the head of the bolt so I can use a flat-tip screwdriver. I don't thread the passage completely to bottom. I want the "plug" to seat on the unthreaded portion. ![]() Also of note, if you are using almost any aftermarket kit, these kits use a feed plate between the support plate in front of the valve body and the seperator plate. This feed plate dual feeds the directs and plugging this hole is unnecessary. Also most manual valve bodies, trans-brakes, etc will have you omit the direct drum center seal and the sealing ring on the stator but plugging of this hole is also unnecessary due to the design of the seperator plate. Don't assume you need to plug this hole. Only plug this hole if you plan on building a unit yourself. You can omit the center seal, plug this passage, enlarge the 2nd and 3rd feed holes in the stock seperator plate and you will have greatly increased the torque capacity of a stock TH350 as well as gained a firmer shift. Even firmer shifts can be accomplished with checkball removal and modifications to the accumulators. I recommend NOT modifying the 1-2 accumulator. Retain the cushion spring and do not block the circuit. The 2-3 accumulator can be blocked by several methods. Removing the 2-3 accumulator spring and using a spacer (nut, washers, cut down section of tubing) between the piston and the e-clip is the "shadetree' method. You can also block the feed in the valve body to the 2-3 accumulator. Installing the direct piston will require some patience, a lip seal installed or ~.010" feeler gauge, and a trick I use is a section of plastic cut from a 3 liter soda bottle to use as an outside installer tool. Set it in the drum, and it will force the lip seal into the drum without using a tool around the entire circumference. You may however need to work the exposed part of the seal into the drum with the feeler gauge or seal tool. Use care using the lip seal tool, I use a push-in technique more than a work around the drum technique. If you slide around the drum, and it catches the seal it will cut it and then you must get a new lip seal and start again. Good lighting, patience, and technique are key here, oh, and a good air check Once you have the piston seated in the drum you can install the return springs and retainer. ![]() You can buy or make a tool similar to the one pictured or use 2-3 5" or larger c-clamps (much more of a PITA). |
#5
Forward drum procedures are almost identical. No center seal to worry about on a TH350, it typically already has a 5 clutch pack, except light duty applications.
Forward clutch pack clearances can be tighter than usual, however it must have some clearance. If too tight it can creep in neutral. Forward drum inspection: Pay attention to this portion of the input shaft, it goes into the outout shaft bushing. It is a high wear area. Be sure it is smooth. Minor scoring can be smoothed down. ![]() ![]() Notice the scraped and split low reverse friction in the intermediate piston cavity. This slightly tightens the intermediate clutch clearance to achieve cleaner 1-2 shift. ![]() Intermediate piston installed ![]() Sealing rings on the pump stator. Notice the missing selaing ring 2nd from bottom. You can remove this ring if dual feeding. ![]() Pump gear install. Note the orientation of the tangs on the inner gear. They are offset. They should face away from the seal. Mis-installation will result in pump failure and converter damage. ![]() Notice the dowel pins threaded into the case, you use these and the case to align the pump halves. ![]() This is an example of how I air check the forward and direct drum. After everything is assembled, I place the drums on the pump (above a hole in the bench) with all sealing rings in place, thrust washers or bearings. Use a rubber tipped air nozzle to apply air to the passages around the pump circumference. As you apply air to the correct passages, you will see and hear the drums apply the clutches. Be sure there are no leaks from the lip seals. There will be some minor leakage at the sealing rings usually. Iron rings air check better than teflon on the bench. ![]() Drums installed in the transmission. Ready for intermediate pressure plate install. Ensure the lugs of the direct drum are engaged with the sun shell. They should be slightly below the top edge of the suin shell. If you do not get complete engagement, the input shaft will not turn when you install the pump and begin to tighten it. ![]() Coan reverse manual valve body. Notice the machining of passages. |
#6
![]() Brass screened filter allows for more flow. Here's a pic of the feed holes. These regulate the amount of fluid, or how fast, it can apply the clutches. Drilling them bigger allows a faster apply. However, bigger is not always better. Remember that as the load increases on the trans, so does the pressure. The increase in pressure will cause the fluid to move faster and shifts to be firmer. If you drill the holes too big the shifts become too harsh at light throttle openings. This causes undue wear on the internal transmission parts, rear differential and axles, driveline and u-joints. The ideal situation is a shift that gets progressively harder with greater throttle openings. I recommend drilling the 2nd feed to .125" and the 3rd feed from .125-.140" ![]() Also not the 2-3 accumulator hole marked in the upper portion. This hole can be blocked but it is easier to block the passage in the VB or the 2-3 accumulator piston as previously mentioned |
#7
Jake, it's great to see you put this here! Are the others soon to come?
Also, I've got another question. I was stacking out the 350 that was in my chevelle the other night... which is destined for my buddys truck (he finally decided to give up on his 700 that kept crapping out on him). I installed the low/reverse retaining ring so it would hold the anti-clunk spring in place, just as the assembly manual said. The thing is though, the ring doesn't seat fully in it's groove in that area (spring is holding it back)... but seems pretty much seated all the way around. I went ahead and put everything else together... but stripped a pump bolt (doh!) buttoning it up. So, I have it partially apart right now so I can repair the threads. Should I do something about that snap ring while I have it apart? |
#8
I would have to see the snap ring, but it should cover the portion of the anti-clunk spring that is flat, but not the part that is turned sideways.
So it doesn't cover the whole spring, just the part that is closest to the 6o'clock position in the case. |
#9
That answered my question, thanks man! I was trying to cover the whole anti-clunk spring with the snap ring, not just the flat portion. I fixed it to where the open end of the ring is over the bent side of the spring and all is well now. |
#10
Jakeshoe, Thanks for taking the time and post.Great thread.
#11
This thread is locked at the present time to avoid spamming of it.
You can email jakeshoe or use the PM system on Hotrodders.
At the Bonneville Salt Flats... 130mph is known as First gear ............... |
Back to top |
Similar Threads for: "TH350 Rebuild Tech"
| good rebuild for th350 400hp+ | roy383ci | Transmission - Rearend | 11 | 06-09-2005 03:02 PM |
| Which rebuild kit? | leastbay | Engine | 7 | 12-19-2004 03:19 PM |
| Lincoln Tech School.. | Mightymouse | Hotrodders' Lounge | 4 | 11-14-2004 04:33 PM |
| th350 rebuild | b/w72 | Transmission - Rearend | 3 | 02-01-2003 05:53 AM |
| Advice on TH350 rebuild please. | F-1Rodder | Transmission - Rearend | 2 | 01-07-2003 07:35 PM |
